Damaris
Hello again,
I know this topic comes up quite often, and I found the snippets to adjust the CSS styles to get a margin after the image block, but it only works for mobile browsers, not on desktop. I tried all the snippets I found here in the forum:
figure img {
margin-bottom: 1.5em;
}.wp-block-image img {
}.wp-block-image figure, figure {
}.wp-block-image {
}All versions do what they are supposed to, but as I said, only on mobile. I’ve got the GP Theme installed on various sites and all show the same issue. Is there anything else I could try?
Thanks in advance!
The CSS should work on both desktop and mobile.
If the issue happens, try adding the CSS to the top of your CSS field to avoid adding it to a media query.
Damaris
That did the trick. I added it first thing in the CSS section, and now it works on desktop as well.
Thanks for the hint. -
