Stack grid on desktop
  • Is there a way to stack the grid on desktop? I want to use a grid so I can control the container order on mobile. Maybe there is a better way to do this?
    select each of the column Container Blocks and set their Width to 100%
    Alternative to using a Grid.
    Add a Container block and set its Layout > Display to Flex, and Flex Direction to Column.
    Then add your containers inside, and you can use the Layout > Flex Child -> Order to re-arrange them
  • Thanks. Setting width to 100% did it.
  • You’re welcome
