mattr2110
How would I set the left container (AD Toolkit DOCS) to stay in place and add scrollbars?
what happens with the header and the footer? As some of that falls above and below that side area – let me know
mattr2110
The header and footer should stay the same.
I’m trying to create pages similar to this payout -> https://stripe.com/docs/no-code/payment-links
Maybe there is a better way to do it?
The Footer makes it a littler more tricky. IF the footer was moved below the main content would that work ?
mattr2110
Actually, I’m ok removing the footer on this page.
Hi Mattr,
Try adding this CSS:
.gb-container.gb-container-e15e8fef.is-sticky-column { position: sticky; top: 0; height: 100vh; overflow-Y: scroll; }
