Cyrielle
I am so sorry if the subject has already been discussed but I have tried a lot of things I read here an I can’t understand why this is not working for me…
I just want to make the image in left column of the grid sticky while we scroll so that the long text in right column can be scrolled and still have the image displayed to the left: https://defis-brigade.instawp.xyz/sticky-image/
I added this CSS, with
mystickyelement
on the image bloc andsticky-column
on the left column (container):.mystickyelement { position: sticky; position: -webkit-sticky; top: 50px; /* Offset from top of container */ } .sticky-column > .gb-inside-container { height: 100%; }
I also tried giving
height:100%
to the 2 columns. But it doesn’t work.Thank you for your help!
try this:
.sticky-column { position: sticky; top: 50px; }
it will make the entire contents sticky.
Cyrielle
I feel silly. So simple!! Thank you so much David for your help as always.
You’re very welcome 🙂
