Drew McManus
I feel like I[‘m missing something obvious, but is there a setting in the customizer to make the sticky nav menu full width? If not, what is the preferred CSS snippet?
to make the sticky nav full width, you need to make the primary navigation full width first.
The option is at customizer > layout > primary navigation > Navigation Width.
Drew McManus
Hi ying, I’m afraid I don’t have that option in that setting panel: https://app.screencast.com/2PWimAw6PN3yQ
But I do have the header and inner header width set to full in the Customizer: https://app.screencast.com/e0nLf2gLVoKFu
in
temporarily change the Navigation Location to Below Header.
You should see the settings appear, set them, and the put the navigation location back to where it was ( Float Right ) -
Drew McManus
There we go, that did the trick, many thanks! 🙏
You’re welcome
