Hello, I ve looked eveywhere in here but I cant find a working CSS.
So I want the last widget of my right sidebar to be sticky.
This code here used to work, but not anymore…I dont know why.
.site-content { display: flex; } .inside-right-sidebar { height: 100%; } .inside-right-sidebar aside:last-child { position: -webkit-sticky; position: sticky; top: 45px; bottom: 30px; padding-bottom: 83px; }
The thing is, if I try the following, then the whole sidebar stays sticky. So it does work then.
.inside-right-sidebar { position: -webkit-sticky; position: sticky; top: 0px; }
Any ideas why the first code doesn’t work at all?
You can see my page in the private info field. -
Try replacing
aside:last-child
in your code withaside:last-of-type
.Let us know how it goes.
It works! So why did the code change?
Also do I need this piece of code if I am already using flexbox structure?
Cause I think it works without it too…
the
:last-child
psuedo-element requires ALL the elements to be the same type eg.<aside>
However, Ezoic has injected a bunch of<ins>
elements for its ad placement in there too. So it fails.
Hence the need to use:last-of-type
as that can handle mixed content.And this:
You’re correct, is not required as the theme adds it.
Thanks so much for the explanation, David.
You guys are always so helpful and I appreciate it so much! 😊
I am so glad to hear that 🙂
