jefferis
https://postimg.cc/XXGnxbZV I imported a site template Aroma) without the images and content, and the menu is not appearing below the tag line as in the preview but overlapping the logo or logo text. I can’t find any way to modify it in the customization settings.
https://thestarragency.com/ All the CSS was created by GP not by me in the Additional CSS area. -
The navigation branding (logo, site title) is set to center by CSS, if you do not want it to be centered, you can remove this CSS:
.navigation-branding { left: 50%; position: absolute; transform: translateX(-50%); }
jefferis
I don’t think I want the menu to appear in that area at ALL as it will crowd the header. I want it to appear below the logo like it does in the Aroma preview. The only way I could get it to do that is to make it appear as a secondary menu rather than a primary one. But when I did so, the main menu still appears across the logo or title in the header
Aroma uses 2 navigations, the primary navigation is the logo and the social icons, the secondary navigation is the actual menus.
If you do not need the social icons, then try this:
1. Go to customizer > layout > header, disable the
use navigation as header
option, setHeader Alignment
to center.2. Go to customizer > layout > primary navigation, set navigation location to below header.
3. Remove the CSS:https://generate.support/topic/template-menu-overlaps-site-logo-and-text/#post-102890
