Andrea G.
Hello I am having an hard time, making titles fitting in their containers.
Can you please help. Video in pvt.
Does the container have a static height set? If so, remove it.
If it’s not the case, can you link us to the page in question?
Andrea G.
Yes, it is!
Of course, please find it in the private section.
A quick note, I need the boxes to be same height
1. select the Grid Block and set its Vertical Alignment to Default.
2. edit the column Container blocks and change theheight
from 320px to100%
This will make all Columns the same height as the tallest sibling. -
Andrea G.
ok, so followed your tip and simplified the containers structures but still not working.
The Grid block’s current
vertical alignment
is set totop
(flex-start
), please set it toDefault
as David suggested:
https://app.screencast.com/TRkph3n5g0hKrIf you are sure the change has been made, then make sure to clear all cache.
Andrea G.
I see! Thanks a lot team! Done
