heathery725
Hi there – I’m tryin to get my text to wrap around image (see this page:https://learnplanting.com/soil-care/fertilizer/ferns/….scroll down to “My Reviews for Best Fertilizers for Ferns”). I’d like my text to be on the left and the image to float right. I found this support page tryin to address the same thing but it isn’t workin for me. I tried to do what what was recommended where the GB blocks is within the same container as the Text and I hit “Float right” but the text does not wrap around it.
https://generatepress.com/forums/topic/text-wrap-around-an-image/
I think a workaround is just creating 2 columns and putting the image in the second column? Like such? https://learnplanting.com/soil-care/fertilizer/monstera/
I search for the keyword searched “My Reviews for Best Fertilizers for Ferns” on the linked page but there is no result.
Can you confirm that you’ve linked us to the right page?
heathery725
oops sorry see this one!
Still nothing: https://www.screencast.com/t/rEIuKYbSlW4U
heathery725
ok please search for “My Reviews of the Best Fertilizers for Ferns”
heathery725
mmm that doesn’t help. If you review the link I provided earlier I know where to click “float right” from Fernando’s support ticket. The issue I’m wondering is how do I actually execute on having the text wrapped around the image – am I supposed to create 2 separate containers (one for the text and then one for the image –> then ‘float right’?) According to Fernandos support ticket I linked it sounded like you should be putting both in a single container and that doesn’t work…
Hi Heathery,
Try reducing the width of the Image Blocks. They are occupying 100% of the width which is why the float right isn’t working.
heathery725
doesn’t’ seem to solve the issue. I can’t drag the image block to get side by side to text (essentially wrap the text around the image) even after making the image block 100% (see here – https://postimg.cc/4YQpTLSL). Any other ideas around making ‘float right’ or ‘float left’ work?
Can you try setting a width first? I’ll see why that isn’t working. Try setting it to 40% for instance.
heathery725
I think the only way is to have 2 containers side by side each 50% and put text in one and the image in a separate container? Is that the way to do it, and then for image you select “float right”? I don’t really understand how this would be different than just sticking each of them in separate containers though..
Setting a width should work. Can you try setting a width first? I’ll see why that isn’t working. Try setting it to 40% for instance. Let me know once you’ve set it.
heathery725
If you look in my Image – I did set the width to 50%…do you mean set the container to be 50% and then put an image inside the container?
It’s still not set to 50% from my end. Can you provide admin login credentials through the Private Information field?
heathery725
yes
Which image are you referring to? If it’s this image, there is no width set yet: https://share.getcloudapp.com/Qwu8NLLx
