We run Formidable forms on a couple of our sites which run GeneratePress. They’ve been running well for awhile, but lately the V3 reCAPTCHA has been buggy and returns the above message, so contact forms are not coming through.
Formidable forms suggests that there is a javascript error on the page or the wp_footer hook is missing from the theme. I’ve deactivated/reactivated our W3 total cache plugin as I thought perhaps this was this issue, but it didn’t fix anything. Could you review the url below and make some suggestions?
There is no javascript error in GP and
wp_footerhook definitely exists in the theme:
https://github.com/tomusborne/generatepress/blob/master/footer.php#L61Have you tried disabling all non-GP plugins and Formidable form to test?
Does the issue exist if you activate a Twenty series WP theme?
Thanks for confirming that GP is built well. I suppose I should have tried isolating the plugin earlier- I deactivated everything, and the problem went away. I reactivated, and the problem has not come back. It’s not consistent which is disconcerting. I’ll monitor but it probably isn’t much to do with GP.
No problem 🙂
