Jakub252
When I insert icon in a headline it is automatically aligned to the middle, this does not look so good when there is more lines of text involved. I want the icon to be aligned to the top (aligned with the 1st line of text) but when I align everything to the top in the flex display layout the icon is slightly higher then the 1st line of text.
(There has been no other changes made then making headline, adding icon and changing the alignment of the flex layout to top)
you can tweak the position of an individual icon by adjusting the padding in the Icon Settings, a couple of pixles of top padding should suffice there.
Jakub252
Thank you David, didn’t consider that.
You’re welcome
