Rishav
hi, how can i stop mobile view of my webside from shifting right and left. To make it fixed?
thank you -
select the Headline:
All About Road Bikes
And in Sizing, remove the Width value – its currently set to 1200px. -
Rishav
hi thanks i did it but nothing changed. It still. shifts right and left.
please guide.thank you
Rishav
it still shifts right only its not fixed in the page.
how to fix it?
thank you -
What change did you make ?
As i still see the Headline has a Width of 1200px.
And it needs to have NO width set. -
Rishav
i pressed edit the page and then selected the headline all about bikes then sizing option i removed it.
but still it moves on the mobile view.
i have checked it again it doesnt show width.
how come it stills shows for you that is still 1200px?
and how to stop it moving? -
Refer to this screenshot: https://postimg.cc/qhF92gcz
That is the headline that David mentioned. As you can see the width is still set at 1200px. Make sure to remove the width value.
Rishav
i understand what you mean but when i go to edit it is shows there is nothing.
can you please explain the prosedure. do i. need to write none in the tap?
i cant understand why it still doesnt change even though there is nothing in the sizing -
Delete that Headline Block, and add a new one for your title.
Rishav
thank you. It works now it moves less than before. its acceptable i guessthis much
thank you. -
Ok, the next issue is in the Footer.
Edit the Footer, in the list view the blocks start like this:Container Block #1
—- Container Block #2
—- —- Grid BlockSelect Container Block #2
Switch to Mobile Preview.
Go to the Sizing > Width and there it is set to 500px. Remove that value
