usethebitcoin
I have copied the code from here https://generatepress.com/forums/topic/display-time-ago/ I placed it in function.php but the result was, not all of the date was change to time ago. What would be the problem about this?
Thank you.
Are you using this PHP code?
https://generatepress.com/forums/topic/display-time-ago/#post-452639If not, can you share your code?
usethebitcoin
Hi Ying,
Yes this is my code.
function time_ago_date( $the_date ) { $time = human_time_diff( get_the_time('U'), current_time('timestamp') ); $updated = human_time_diff( get_the_modified_time('U'), current_time('timestamp') ); return sprintf( '%1$s Ago', $time, $updated ); } add_filter( 'get_the_date', 'time_ago_date', 10, 1 );
Not sure if I missed something, but I just went through every single post on your site, and all the dates seem to be changed according to the format that you want.
Did you manage to fix it?
usethebitcoin
Hi Alvin,
Pls check this image here. https://i.postimg.cc/jj91Zq21/Screenshot-3.jpg
usethebitcoin
Hi David,
Actually its in the Crypto News Articles not in the CRYPTOCURRENCY GUIDE
https://i.postimg.cc/fbzy9tyk/Screenshot-3.jpg
Thank you
In your snippet, the end line:
Try changing the
10
to99
this will fire the filter later, and hopefully stop it from being overwritten. -
usethebitcoin
Hi David,
Thank for this one, this is a big help!
You’re welcome
