formanite22
I also tried the above PHP snippet after deactivating the Pagination Plugin, still the block element disappeared from all the pages (Page 1-5).
I met a guy on internet few years back, who created that plugin for me, will try to contact him. I will let you know later, if I need the CSS solution.
In my first post, I also mentioned another way that, if I insert the container at the bottom of the last page (Page 5) instead of using the Block Element, the container is appearing above the page navigation.
So I would need CSS solution for this too (i.e, to make the container appear below the page navigation on the last page (Page 5)? -
If you disable the Pagination plugin, how would there still be paginations as default static pages only have 1 page.
No, CSS would not work in this case. As they are in the different sections, can not be moved around by CSS.
formanite22
I will decide about the CSS solution later. For now, I’ll close this topic.However, before closing this topic, I have a general question.
Among the two ways, (1) Inserting the container at the bottom of the page (2) Adding container using a Block element.
Which would be the preferred or recommended method? -
It depends on how many pages you need to insert the section.
If not many, then manually inserting the container is ok, otherwise using a block element is recommended.
formanite22
Right.
Thank you so much 🙂 -
