Badgerman
Hi. I’m using the “Prime” site template on WordPress 6.2, GeneratePress Premium 2.3.1.
I want to center align some (HTML) text I’ve put in the Top bar widget. In the WP Customizer (Appearance, Customize, Layout, Top Bar) I changed the Top Bar Alignment setting to “Center”. This has worked for Desktop & Mobile view, but in Tablet view the text is still left-aligned.
Please could you advise how to fix?
Many thanks in advance
Simon
can i see your site ? As i need to see the HTML you added.
Badgerman
Hi David
My site is https://isanflowers2.com/
The code I added is …
<b>Our SHOP is on Corner of Soi 23, Soi Siam Country Club, East Pattaya. <a href="https://www.google.co.uk/maps/place/Isan+Flowers+2/@12.9292784,100.9455122,17z/data=!3m1!4b1!4m6!3m5!1s0x310295f1bf414607:0xfd43a7a2393f06d4!8m2!3d12.9292732!4d100.9480925!16s%2Fg%2F11g8jtsp3g" target="_blank">(HERE on Google Maps)</a> .... Reliable DELIVERY to anywhere in Pattaya (& Naklua, Jomtien, Huay Yai)</b>
Simon
Ok, if you edit the Widget in Appearance > Widgets ( you get the full editor there unlike the Customizer ). And select the Container Block the text is in, and from its Toolbar set the text align to centre.
That should cover all screens
Badgerman
Many thanks David. I found the Text Alignment option in the Typography section.
That has now worked for the Tablet view! Still not quite right for screen sizes between Desktop & Tablet (e.g. small Desktop, as tested by dragging a desktop browser window slowly narrower) but I guess it is good enough
It looks pretty good to me.
If you want to drop me a screenshot of the odd size ill do some digging ? -
Badgerman
Hi David. Many thanks for the offer but don’t worry. It’s good enough for now :0)
Much appreciated
Simon
OK 🙂
