wkern74
I didn’t see my previous post, so sending again in case it didn’t go through…
I am trying to decrease the spacing between the two columns in the image below in my top bar. It appears all padding, spacing, etc. is already at 0 so how do I do this?
Thanks,
Wyatt -
check the Inner Contaienr Blocks padding.
And the check the Headline Blocks Margin, you may need to set the bottom margin to a value so they don’t inherit the themes spacing -
wkern74
Thanks. One more thing. For mobile, I’ve made it into a column so it looks nicer. However, when I open the website on mobile, only the top headline shows. Do you know why this would be?
Any chance you can link us to the site in question?
You can use the private information field.
wkern74
Hello Leo,
Sure, I will put the information in the private box below.
Thanks,
Wyatt -
The Container Block that your 2 columns are in, has a Sizing > Height of 35px. That needs to be removed or at least increased on mobile size
