Transparent background menu only in mobile
    I used a hook element to have a transparent menu, but I only want it in mobile version. How can I do it?
    Here some screenshots: https://app.screencast.com/1Lilmb6FEQxed
    In private information there is the website.
    Thank you!
    Remove the header element, we can use CSS to change the background color of the mobile header.
    nav#mobile-header {
        background: transparent;
  • Hi Ying,
    Thank you for your reply. I tried you comment but it is not I need.
    I need as it is now, but in the PC it should always be white background menu and fixed.
  • Have you done this?
  • Hi Ying,
    Yes, I tried it, but the elements inside the menu are white too, so if I set a white background color in the menu, the elements are not visible.
    When the bakground color is transparent I need white elements inside. When the background color is white I need black elements inside. Plus there should be a transition between transparent background and white transparent.
    Thank you for your help,
  • Can you just disable the header element then we can see what CSS is needed?
    If you keep on refusing my suggestions, I don’t know how to help you!
  • Sorry for my delay response. The header element is now disabled. Waiting your feddback. Thank you!
    can you re-add the site URL in the Private information, as out server auto removes that after a period of inactivity.
  • Hi David,
    Sure, here you have. Thanks
  • Try this CSS:
    nav#mobile-header:not(.is_stuck) {
        background-color: transparent;
        position: absolute;
        top: 0;
  • Thank you Ying! Only one thing is missing: When background is transparent, the logo and icons are black and it should be white. When background is white, logo and icons should be black (and it is now yet).
    Thank you all again!
    try this CSS:
        --contrast: #fff;
    #mobile-header:not(.is_stuck) .site-logo.mobile-header-logo img {
        filter: invert(1);
  • Hi David! That’s it! I didn’t know this lines. Thank you all very much for your help! Hope you have a nice day!
  • Glad we could be of help
