haseltinedesign
I have three rows with alternating images and text in each column on my home page.
It looks great on desktop, but once you start to squeeze the window down to tablet vertical size, the images don’t cover the height and reveal white space beneath them. I need these images to stay at max height centered. They are not backgrounds, they are just images.
https://snipboard.io/xLBzNu.jpg
Any recommendations on how to do this properly? I’ve tried so many different ways including GenerateBlocks and Otter page builder.
Thanks again in advance!
can i see the site ?
haseltinedesign
Yes – https://www.staging3.silverliningsailing.com/
It’s in staging so it may throw an SSL error.
OK.
1. Add this CSS to your site:.has-object-fit-cover figure { width: 100%; height: 100%; }
2. Select the column Container Block that has your Image Block inside.
2.1 set the Sizing > Height to100%
2.1 in Advanced > Additional CSS Classes add:has-object-fit-cover
3. Select the Image Block
3.1 set its Height to100%
3.2 set its Object Fit toCover
haseltinedesign
Worked like a charm – thanks for the help!
Glad to hear that
