Leonardus
Before updating the plugin on my website, I made a test website that looked almost perfect.
Now I’ve done the update in the actual site (copied all settings plus extra css) and I have some unexpected results. For instance:
The margins between headlines/publishing date on mobile are different from the ones in desktop and tablet view. Can you please tell me where I could fix that.
(url’s in private information)
Desktop
Mobile
Thanks, Leon
Hi Leon,
Can you try adding this CSS?
@media(max-width: 768px) { .post-image-aligned-left .post-image,.post-image-aligned-right .post-image { margin-bottom:0; } }
Leonardus
Thanks Ying,
This works nicely for the pages “Columns” and “Dossiers”, but not on the homepage or archive.
Could you maybe fix that as well?Kind regards, Leon
I wrote the CSS for homepage and archives, doesn’t it work?
It should NOT affect your Columns page as it’s built by WP query loop block.
Leonardus
Hi Ying,
You are right: it does NOT affect the columns and dossiers pages.
However, it also does NOT affect homepage and archives page.On the images you see the effect on these pages:
Home
Archives
Thanks, Leon
try this CSS:
@media (max-width: 768px) { .post-image-aligned-left .generate-columns-container .post-image, .post-image-aligned-right .generate-columns-container .post-image { margin-bottom: 0; } }
It will make the Yings CSS a little more specific so it should override the current style.
Leonardus
Hi David,
Unfortunately the new css had no effect.
I hope you can think of some other solution.(strange enough, the test site doesn’t have the same issue.)
Thanks, Leon
See here:
https://app.screencast.com/ynmdESLVc81GY
The previous CSS rule is missing its closing
bracket, so the CSS below won’t load. -
Leonardus
Hi David,
Rather embarrassing, but that was it.
Leon -
Mo problem, glad to be of help!
