abently
Hi guys,
Getting this error at the moment. After trying to debug the fault it seems shortcodes (or specifically WP Show Post) is giving me this error.
Is this something the team is aware of? How can I work around it?
TIA
Luis
Previous users who encountered this same type of error found it related to ModSecurity settings on their server.
https://generatepress.com/forums/topic/issue-editing-elements-the-response-is-not-a-valid-json-response/#post-2318842
https://generatepress.com/forums/topic/updating-failed-the-response-is-not-a-valid-json-response-trying-update-pages/#post-2160217You may want to reach out to your hosting support to see if this is the same case.
abently
Hi Alvind,
Wouldn’t this stop all posts being saved or updated? Because any new posts I make without the shortcode inserted can be saved as normal.
Luis
whilst in the editor, can you right click and inspect the page to open the browser developers tools.
And check in the Console tab for any red errors, before and after theUpdating failed.
notice appears. -
abently
Hi David,
I had a look and couldn’t see anything obvious.
I’ve made an account for you, please have a look and see what you can find.
It probably only started happening sometime in the last few weeks.
Luis
If you notice, even though there is an error when saving the post, it actually does save. You can confirm this by viewing the post on the frontend.
Have you tried re-saving the permalinks?
abently
Hi Alvind,
Yes it appears to save most of it.. hmm. But any changes I make to SEO title, Meta description etc are ignored though. =(
Yes, I have resaved permalinks.
Any ideas why this is only happening with shortcodes?
Luis
I’m not entirely sure why that’s happening. The browser console isn’t showing any warnings either, so there’s no clue as to what the problem might be.
Could you check the Tools > Site Health section to see if there are any critical issues that need addressing? I’m unable to view them even after logging into your site because the account role isn’t admin.
abently
Site Health is just showing this >
PHP modules perform most of the tasks on the server that make your site run. Any changes to these must be made by your server administrator.
The WordPress Hosting Team maintains a list of those modules, both recommended and required, in the team handbook(opens in a new tab).
Warning The optional module, imagick, is not installed, or has been disabled.
Warning The optional module, intl, is not installed, or has been disabled. -
Install the Query Monitor Plugin:
https://wordpress.org/plugins/query-monitor/
It will report any errors that occur on the page, let us know if it shows anything before or after the Update failed notice occurs
abently
Hi David,
I don’t know how often this happens… but the problem has seemingly disappeared. =)
I have some suspicions / theory but I’ll wait for it to remerge (if it does) before confirming.
Thanks for all the help!
Luis
Glad to hear that, hopefully it doesn’t re-emerge 🙂
