MoleculeMarketer
I have a page on my site which is called Newmarket Racecourse and in one container which I took from the Generate Blocks library it has two shapes (triangle at the bottom) I’d like to create the same effect at the top of the container but not sure how this works.
I am trying to get the same effect at the top where the jagged white blends into the page.
I have added a screenshot in the private info section.
Regards
if you select the Container Block that the shapes are attached to.
In the sidebar block settings > Shapes you can edit the Shape and change its Location to TopMore info here:
https://docs.generateblocks.com/article/shapes-options-overview/
MoleculeMarketer
Hi David,
I understand that I can add another shape and place it at the top, but I am struggling to get the same effect as the bottom shapes on the screenshot I sent you.
Cheers
So that design is using 2 shapes set to the Bottom, their the same shape just different colors and different heights.
Can you try duplicating both shapes by adding new and using their same settings ? And then switch the position to Top
MoleculeMarketer
Hi David,
I have managed to do that with the shapes but it has presented another problem.
I have created a reusable block from that container now and have duplicated it on the page, but If I edit any content in the reusable block, it changes in all the blocks I have copied.
e.g. If I edit the headline to Newmarket Horse Racing Museum it changes it in the four blocks I have on the page.
How can I use the block and then edit each element separately?
Cheers
If you select a Re-useable block, from its toolbar menu you can select Convert to Regular block
MoleculeMarketer
David,
Thanks so much for your help, that is all sorted now.
Regards
Richard
Glad to hear that!
