YEAR93
I have a page containing containers below each other with a background image. Both have content inside. I want to vertically center this content inside the container containing the background image. And also align the arrow down button to the bottom of the container. How can I achieve this? I’ve added a screenshot for reference and a link to this specific page.
The structure you are using has 1 too many container, can you make the structure into this?
- container A -- container B --- headline --- headline --- headline -- button
1. select container A, use the flexbox alignment matrix to align the container B to center.
2. select the button, set
z-index
to2
.3. add a CSS class to the button, eg.
stick-to-bottom
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/4. add this CSS, note the 30px is the half of the icon width.
a.gb-button.stick-to-bottom { position: absolute; bottom: 50px; left: calc(50% - 30px); }
Let me know if this helps!
YEAR93
Perfect! Thank you, it worked. However, it seems like the content is still pushed down a bit. I’m not sure what is causing this. Could you please take a look?
You can set the top margin of the container to something like
-500px
to push it up. -
YEAR93
Okay, but isn’t there another way to vertically center this container without it being pushed down? There must be some element or something that is causing it not to center vertically. Because the container settings are correct now for this.
It’s not. It’s right in the middle. It’s visually pushed down as the container is 100vh in height, but the site header pushed the container down, so you can not see the full height of the container, and because of this, the inner container looks like positioned in the lower part of the container.
I removed the header, and you can see the full container:
https://app.screencast.com/vgsGFp6vpfK9wSo the best option is to calculate a proper height for the container, which is 100vh minus the header height. Which means change the
min-height
of the container from100vh
tocalc(100vh - 101px)
YEAR93
Thank you for the detailed explanation. I understand now. Should I add the
min-height: calc(100vh - 101px);
as custom CSS, or is it possible to add this to the container in the GB editor? -
You can directly add this into the
min-height
field. -
YEAR93
Perfect! Thank you. I have an additional question. On mobile, when you click the arrow down to go to the section below, it looks like the content isn’t vertically centered, but on desktop, it does. Is this normal?
Mobile header is taller than the desktop header, you need to change the
min-height
for mobile tocalc(100% - 122px)
YEAR93
Thank you, so if I’m understanding correctly it’s
calc(100vh - [header height])
I forgot, it’s been more than one month.
Without seeing your site again, I can’t recall where the value came from.
However, you can try it. Play with the mobile header height and the
min-height
value to check. -
YEAR93
I’ve added the details for viewing my site. Please review and let me know.
Thank you, so if I’m understanding correctly it’s calc(100vh – [header height])?
That’s correct 🙂
YEAR93
Thank you. The height of my header has changed in the last week because I reduced padding and other settings. Could you please check one last time if I’m using the correct values for the
min-height
on the ‘Who we are’ page? Currently, I’m still usingcalc(100vh - 101px)
andcalc(100% - 122px)
for desktop. -
It’s 85.03px both on desktop and mobile.
