GillanBoyer
I have a custom post type with a custom page template built with GenerateBlocks. Here is an example: https://thebrokerageinc.com/video/the-latest-from-ameritas/
For some reason, the Vimeo embed suddenly shrunk down the page. We didn’t make any changes. Before, it took up the full size from the left to the right sidebar.
The cause of the issue is that the video has an inline style setting 80% top padding.
https://app.screencast.com/WnYrKBeAXNF2YIt’s not added by GB, please check the embedded code or reach out to the video provider.
GillanBoyer
Thank you, Ying. I removed the top padding, but as you can see, the video is still shrunk down pretty tiny. https://thebrokerageinc.com/video/the-latest-from-ameritas/
Here is the current embed code: <div style=”padding:0 0 0 0;position:relative;”><iframe src=”https://player.vimeo.com/video/937940972?badge=0&autopause=0&player_id=0&app_id=58479″ frameborder=”0″ allow=”autoplay; fullscreen; picture-in-picture; clipboard-write” style=”position:absolute;top:0;left:0;width:100%;height:100%;” title=”The Latest from Ameritas”></iframe></div><script
It seems like the problem is with GenerateBlocks? I would think this video should be displaying full size since it is set width and height to 100%. Unless I’m missing something?
GB just outputs HTML, it won’t interfere with what that iframe is doing.
If you Right Click > Inspect the video to open the browser developers tools you can see its frontend HTML:
<iframe frameborder="0" title="The Latest from Ameritas" class="perfmatters-lazy entered pmloaded" data-src="https://player.vimeo.com/video/937940972?badge=0&autopause=0&player_id=0&app_id=58479" data-ll-status="loaded" src="https://player.vimeo.com/video/937940972?badge=0&autopause=0&player_id=0&app_id=58479"></iframe>
As you can see it has no style attribute as per your original HTML. I would suspect thats because PerfMatters LazyLoad has altered that.
