iammak45
Hello, Team Generate Press,
I’ve installed Volume site builder, and it’s looking good. However, the navigation header isn’t showing on the mobile page.
Can you please help me how to display it?
Your site doesn’t look like the Volume template, as far as I can see it’s built with Elementor. This is what I see:
https://app.screencast.com/TDg2Ps2GZPB07Can you make sure the site’s cache is all cleared so I can see the new version of the site?
iammak45
Yes, Header, Footer, and Frontpage are built with Elementor.
I’ve imported the Volume Template for single post layout only.
The problem is The navigation header appears on the Desktop but not on the Mobile. https://imgur.com/a/Kui4dHj
iammak45
Here’s the list of elements (private info box)
I would say that if you choose to use Elementor for everything else then you should also use Elementor to build the single post layout and avoid importing anything from the site library – that’s not what the templates are intended to do.
I’m also not seeing the problem using Chrome device preview:
https://www.screencast.com/t/Rbj0SCXb -
iammak45
So, I shouldn’t use it volume template for single post,?
Importing the template means importing everything including pages, posts, theme settings, elements, etc, but most of them are not useful on your site., and might mess up with your existing content/settings.
I would recommend removing the template.
iammak45
But what if I use only elements instead of importing entire template? Can you recommend this?
theres nothing stopping you from installing a site library on a dev or local site, and then copying what you need from one site to an other.
iammak45
Okay, thank you.
You’re welcome
