brtekim79
We are using the generator block loop to dynamically load ACF data using include post function.
By the way,
If I update the ACF data field using All import,
It is not being updated in real time. << Real timeWhat can I do to get it updated?
I have a question.1. After a day or two, the update will be automatic.
2. I have to recreate the loop block for updates of ACF Dataps.
How long will it take if it is updated automatically?
I have confirmed that it will be updated if I erase the loop and create it again after updating the current ACF data. -
Sorry, but I don’t quite understand the issue you have here.
The Query Loop block will display data based on the parameters you’ve set in the Block settings. When there’s an update to the ACF data, it will automatically fetch the updated data if your query includes that particular updated data.
There is no need to recreate a new Query loop for that.
brtekim79
sorry.
I have other problems.
I solved it. -
No problem, glad you’ve managed to find a solution.
