Daniella22
Hi
I need to insert my popup opt-in form in my site. Can you tell me where I can put the code, please?
Thank you!
1. go to Appearance > Elements -> Add New –> Hook:
https://docs.generatepress.com/article/hooks-element-overview/
2. set the Hook to:
wp_footer
3. set the Display Rules > Location to
Entire Site
or the pages you want to display it on.4. in the editor add your code.
5. Publish the element
Daniella22
Hi David,
Thank you for the reply. I’ve set up the option from as you suggested but it’s not working. Here is the domain of my site: allnaturalearth.com. Maybe you can take a look? Thank you again. -
Daniella22
Hi again. I see it’s working, but it’s located in the footer, and it’s static. It’s a popup opt-in form that opens when the readers read the content.
Can you elaborate on how you expect this popup to show up? Should it appear when the user opens the post content, or when the user scroll to a certain viewport?
Daniella22
Hi, I want the popup to open while the readers read the article. Not right away, though:)
The code you have for the pop up – where did it come from ?
As that code i assumed would contain all that is required to make it popup -
Daniella22
Hi David, it comes from Ewaber.
Can you share the code here ?
Daniella22
Sure
Daniella22
<div class=”AW-Form-808410087″></div>
<script type=”text/javascript”>(function(d, s, id) {
var js, fjs = d.getElementsByTagName(s)[0];
if (d.getElementById(id)) return;
js = d.createElement(s); js.id = id;
js.src = “//forms.aweber.com/form/87/808410087.js”;
fjs.parentNode.insertBefore(js, fjs);
}(document, “script”, “aweber-wjs-6ssabky3p”));
</script> -
And did Ewebber state it would be a pop-up ? Or do you need to create the pop-up separately ?
Daniella22
No, it gives the option in the setting to create a popup within the option form.
then i assume the code should automatically work.
Can you add the code to the site using the Element, set it one post, and then provide us a link – we can then check for any obvious errors. -
Daniella22
Yes, I’ll set it up in the hook and send it to you.
Daniella22
I’ve set it up in the element, but I don’t see how I can copy the link to send it. The only option the theme gives me is from the element inside the site; I don’t have any URL. How can get the URL?
