connect4consulting
Trying to create this page in a contained layout but it is appearing full-width.
Page is in private information.
Many Thanks!
Gabe -
You have set block alignment to
full width
for some WP group block/columns block, make sure set the alignment to default. -
connect4consulting
I reset them to default and Still no change.
have you cleared cache? I’m still seeing them as align full:
https://app.screencast.com/sDSyo5mCbCYm4 -
connect4consulting
Yes cleared the cache and confirmed it’s set to default.
When you’ve set the Alignment to None (Default), the
alignfull
class should go away. Seems like it is not the case.Alternatively, you might want to consider replacing the WP Group block with the GB Container block for much better control and responsive adjustment.”
