Anonymous
I am trying to get one of my google review widgets to the left or right side of the footer. The problem is that it makes an extra white bar. I am trying to get it infront of everything and have it scroll with me from the top down and vice versa. Have tried the hooks for generate_footer.
<div class="tr-widget" data-id="6026" data-view="list" data-lang=""><a href="https://trust.reviews/" class="trcr" target="_blank">Powered by <span>Trust.Reviews</span></a></div><script type="text/javascript" src="https://cdn.trust.reviews/widget/embed.min.js" defer></script>
An example could be from here. https://trust.reviews/#about
Thankyou
can you share a link to your site where i can see the issue ?
Anonymous
Sure i have provided a temp login since it is in maintenance mode.
Some CSS like this can be used to fix its position:
.tr-widget { position: fixed; z-index: 100000; bottom: 20px; left: 20px; }
You can change the
left: 20px;
toright: 20px;
to flip sides
The20px
is how far from the browser viewport side it sits.What would be the expectation on smaller screens ?
You may want to consider hiding the one at the bottom of the screen and adding it elsewhere too -
Anonymous
Thanks for that,
My plan was to have a close button or just not have it for mobile etc.
To close it, you would need to check if the widget has that option.
For now if you use this CSS:@media(min-width: 769px) { .tr-widget { position: fixed; z-index: 100000; bottom: 20px; left: 20px; } } .tr-widget { text-align: center; }
then on small screens it will just center itself below the footer. Where it won’t get in the way.
As a note, you could add the widget anywhere on the site eg. as a footer or sidebar widget, where it could remain on Mobile. And that CSS above would still work for larger screens.
