aaronmckeon
I have a video that plays as the background to the homepage, which I did by adopting code I found in the following documentation:
https://docs.generatepress.com/article/adding-a-background-video/
Can you tell me if you know of a way to add a button that allows the user to unmute the video? It’s muted by default but my client would like users to be able to play the audio. This would ideally a button that floats over the video in one of the corners.
Unfortunately, we are not aware of a solution for this.
You may need to research to see if a plugin is available for this.
If not then your best bet is likely to hire a developer using a service like Codeable (see bottom of this page) to create a custom solution for you:
https://generate.support/what-support-includes/I hope this helps and thanks for your understanding.
aaronmckeon
I was able to figure out a solution. I added a button into the container that overlays the video, and then added a script to the custom HTML block.
<script> document.addEventListener('DOMContentLoaded', function() { const video = document.querySelector('.am-background-video'); const muteBtn = document.querySelector('.am-mute'); muteBtn.addEventListener('click', function() { if (video.muted) { video.muted = false; muteBtn.textContent = 'Mute'; } else { video.muted = true; muteBtn.textContent = 'Unmute'; } }); }); </script> <video loop muted autoplay poster="/wp-content/am-uploads/homepage-video.png" class="am-background-video"> <source src="/wp-content/am-uploads/homepage-video.mp4" type="video/mp4"> </video>
And then a little CSS:
.am-mute { cursor: pointer; }
Worked like a charm. Hope this is helpful.
— Aaron
Thanks for sharing your solution!
