Anonymous
Hi-
I have a weird problem.
I just created two new WP installations, one a clone of the other.
Installed my usual set of plugins, Generate Press as the theme, Generate Blocks Pro as my backbone.
But in containers, in the advanced settings for the Block Label, is missing. It’s really weird the rest of the items are there but block label item is gone. How is that one thing missing do you think? I use it heavily on my sites.
Ideas? 🙂
Thanks -
Can you disable all other plugins except GB and custom functions to test?
Anonymous
Well, that is certainly not an easy step on a live site. Why would it work on all other sites, with the same and more plugins, but not on this one?
Anonymous
I did it on the not live one, in Troubleshooting mode, with only Generate Blocks and Generate Blocks pro active and it’s still not there.
Can you create a staging site so we can do a test?
Please provide an admin login to the staging site.
Anonymous
You want me to create an entirely separate site to test it?
Or can I test it on your live site with all plugins disabled? i thought you were not ok with that.
Anonymous
One of the sites, the cloned one, is not live so you could test it there. It doesn’t work on the original site, nor the cloned version of that. Neither of those are live. The live site, it works fine but that is the one I’m re-creating in the new (not live) version. I’ve provided log in details in the private box to the not live yet one where it doesn’t work.
Every site has the same set of plugins and works fine. The new one with the cloned version, doesn’t work on either of those which have less plugins but no different plugins from the ones it works fine on.In the non-live site I’ve provided a temp access for in the private box, it shows up on some elements and not on others. See links.
I disabled all plugins, and the block name option is there in the page editor:
[screenshot removed]Activate plugins one at a time to check which one is causing the issue.
Anonymous
Please see private window.
Anonymous
And see another…
Anonymous
And another
Anonymous
Block name was never the question. Block LABEL was the question. It appears on some elements and pages, but not on others. Block name is there on all. Block Label is where I have all of my blocks named on all of my sites, not Block Name. Should I be using Block name instead? I’d have to rename about 1000 blocks if so.
Anonymous
Remove screenshot.
Anonymous
And for clarification, as I mentioned, I already did go into troubleshooting mode, with only GP active, and Block LABEL is still missing from most but not all of the containers/pages/elements so I don’t believe it’s a plugin conflict. And yes I would prefer you don’t disable all of my plugins.
Anonymous
And I put very specific clear links in the private box to which ones you could see BLOCK LABEL on and which it’s missing on.
