Alexis822
Sorry but there’s a bug on the accordion menu when it’s opened or closed at the icon level. Both remain displayed. I don’t understand why
Can you provide an admin login for us to check the backend?
The accordion seems loading different CSS than the one it should be loading.
Alexis822
In fact, I made it from your colleague’s code. Here are the accesses. https://generate.support/topic/create-section-customized-problem/#post-82445
did you change the Accordion Title Type to Container ( its default is button )? And then drag a button inside that container … as thats what i see.
Alexis822
Yes I Do because there is subtititle
And thats what broke the accordion icon.
Remove the accordion button you added back inside the container.
And see my reply here which explains how to add the icons:https://generate.support/topic/accordion-title-expand-button-disappeared/#post-80323
Alexis822
I don’t understand because if I replace the button with another title to have subtitle + title The accordion menu no longer works
You are editing the page, I’m not able to see the backend.
However, I’m not sure what you mean by if I replace the button with another title to have subtitle + title The accordion menu no longer works
It definitely works, we would not offer a feature that doesn’t work. Can you give it a try?
Alexis822
I’m no longer on the page. From what I understand, I had to change the button to a title
Change the button to a headline.
Alexis822
Here I put a title but it no longer unfolds
Your accordion structure is corrupted by your previous changes.
I would recommend starting over from scratch and making sure you do not drag the accordion button into the accordion title container.
Alexis822
It’s ok thanks
Glad to hear that 🙂
