kevinbk
I tried to use the Shortcode [acf field=”lista”] inside the QueryLoop and it does not work, the same shortcode that I already use on the page, but inside the query it does not work, as if I were trying to retrieve the field of the current post and not from the queryloop post.
The same happens if I use Dinamic Post_meta the same as the image that was sent. It is also blank if there is nothing in the postmeta table, are you sure it is running get_field? Because get_field is to work.
Shortcode does not work in query loop, it’s a WP thing.
You will need to use
render_block()
todo_shortode()
.Something like this:
https://generate.support/topic/reading-time-with-generateblocks/#post-86125 -
kevinbk
Is there a way to make the dynamic meta_post query get_field instead of get_post_meta? It seems he said there’s a way, but I still don’t understand. By default, it’s not working. I would prefer to use the default to display the custom_fields that make ganbiarra with shortcodes and block renderer.
If you are using GB PRO, when pulling the dynamic post meta from the dropdown list, GB should be using
get_field()
.But if you do not have GB Pro, there isn’t a way to switch
get_post_meta()
toget_field()
within the blocks, unfortunately.Unless you use
render_block()
to render each block usingget_field()
kevinbk
So, there’s the problem, I’m using GB PRO, how do I know it’s really pulling get_field? Because it still doesn’t work in queryloop using Dynamic Post Meta.
kevinbk
Aaaaah, Now I understand what you were talking about. If I use the option inside the block, it will work, only the one in the floating menu does not work. Now everything is solved, thank you very much!
Glad to hear that 🙂 Sorry I didn’t make it clear that the GB options are in the sidebar.
kevinbk
I’m sorry, as I’m not fluent in English I get totally lost in the conversations, even using translation. And sometimes I can’t express myself correctly just with the translation.
No worries, all good! 🙂
