hws991215
g <– I wish the button would automatically respond when you place your hand there, like on this site.
<– Site shown in screenshot<– This is my site, but on my site, I need to add separate links to containers and buttons. I want to complete it so that the button is automatically activated even if I just put a link in the container.
I’ll give you the login information and explain what to do with screenshots or videos.
Try this CSS:
.gb-container.go-quickview >a.gb-container-link:hover + .gb-grid-wrapper a { background-color: #4285f4; }
and you should be able to remove this CSS:
.gb-container.go-quickview .gb-grid-wrapper .gb-grid-column:nth-of-type(4) { position: relative; z-index: 100; }
hws991215
<– Thank you. Let this part apply too
hws991215
<– Thank you. Let this part apply too.
1. Add this CSS:
.gb-container.has-hover-effect:hover a.gb-button { background-color: #4285f4; }
2. Select the Container Block you want the hover effect applied to.
In Advanced > Additional CSS Class(es) add:has-hover-effect
hws991215
<– Please check.
<– Please check.
<– Please check. -
Update David’s CSS above to this:
.gb-container.has-hover-effect:hover span.gb-button { background-color: #4285f4; }
Then simply add the
has-hover-effect
class to the parent container block that contains the button. -
hws991215
<– Thank you. But here, if I put a link in the container, I want it to go to that link even when I press the button.
<- The container here is working as I want. Let it be like this.
Why not put the same link on the button too?
You need to add the class
has-hover-effect
to the other containers as well. -
hws991215
This is because entering a link multiple times is not good for SEO and is too cumbersome.
<– Here, the link is only included in the front container, and even if you press the button, you will be taken to that link.
<– But I applied the same thing here, but even if I press the button, it doesn’t move there. Why is that so?
When you post a screenshot with the issue, can you also include the link to the page in question?
hws991215
<– Since this is a private post, you can view it by logging in to my site.
Select the button and set the z-index value to
0
https://postimg.cc/fSX5YW7N -
hws991215
thank you. But the effect settings do not move.
You can adjust the effect in the settings if you want, similar to what you did with the containers above it.
hws991215
I’ve already set it to that button, and it seems to work in the text editing space, but it doesn’t work when I go directly into the post. Please take a look and see why. Thank you.
