but it doesn’t work when I go directly into the post.
It seems working properly, when hover on the container, the button color changes:
https://app.screencast.com/tCXDINr2z0Aky -
hws991215
I know that. What I’m talking about is that I set the ‘Effect’ settings to the button. You will find out when you check for yourself. The button should go up and then down.
When hovering over the container, the button is not being hovered, as you are hovering the container link. So the hover effect added for the button will not work, do you understand this?
You need to set the effect to the container and use a custom selector
.gb-button
to add the hover effect. -
hws991215
Please tell me how to do it with a screenshot or video.
This is how you set up the container effect: https://app.screencast.com/p4I7qMZgDNxxj
Then remove the translate effect from the button.
hws991215
Thanks it solved it.
No Problem 🙂
