Tsken
Heya,
Yes that seems to fix the loading of the elements when I disabled the CDN.
I already turned off the caching.When I turn it back on – it goes away again, so i need to flush the CDN as well?
It’s a little odd it only effects the front page though.
Thanks for all your help guys I really appreciate it.
I will look into the CDN later and then come back and mark it as resolved. If that did the trick.Best regards
CDNs and caches can be a pain, and sometimes take time to propegate changes.
Best solution is to disable them whilst developing and re-enable them once complete.If its a live site you’re working on and you don’t want those to be disabled for too long, then ask your host about a Staging site.
This is a clone of your live site, where you can make updates in isolation and then when you’re done the host can push the staging site to live. -
Tsken
Hi David,
Yes indeed – they sure are annoying. It’s not a live site so for now I just disabled them!
Thanks again!
You’re welcome !
