Jeroenpress
I have trouble wrapping text around an image. I found this topic: https://generate.support/topic/text-wrap-around-image/ .
I tried using two methods; both paragraphs and Generate Blocks Image in one container, using float right on the picture and secondly in a grid using two containers.
The first method makes the text go through the image, the second method doesn’t let the text go below the image.
The first method requires the image to be added before the text, not after.
Can you give that a try?
Jeroenpress
That worked. Now I like to do this as well with the mobile version. It keeps putting it on top no matter how small I make the image. Can I make the image appear to the right in mobile as well?
Hi Jerroenpress,
This is what I’m, seeing on mobile: https://share.getcloudapp.com/6quJ9E2z
How do you want it to look like?
Jeroenpress
I like to have more control over it. I see now depending on the device (resolution) it either appears above the header (like with in Chrome as IPhone SE 375×667) or to the right quite messy. Is there a way to make it for example show below the last paragraph in the container for mobile (or below a certain resolution).
It is important for me to have a consistent neat look. How it looks on higher resolutions right now is good.
What if you choose Align center for the image block on mobile?
If you want the image to be at the bottom on mobile, set the Container to display:flex, direction:column-reverse (column + up arrow) for mobile.
Jeroenpress
“If you want the image to be at the bottom on mobile, set the Container to display:flex, direction:column-reverse (column + up arrow) for mobile. ”
That works except that it also puts the headline block (from Generate Blocks) to the bottom. I tried to make it work with putting the headline and paragraph in a container but then it doesn’t work as intended on higher resolutions anymore (there it also then shows the image at the bottom).
Is there a way to make it work with containers like above (two for the text and one for the image)?
Put the 2 headlines into one container, so the structure would be:
-Container -- GB image -- Container --- Headline --- Headline
Jeroenpress
Great now it works as I intended it. Thank you!
