Anonymous
Hi David,
When I am there, I am making changes, but under older behaviour, it was showing the changes visually to the right on the website. So changes made, but nothing appears to change on size.
Anyway to revert back to a default to see if I can do this …do you have videos for the customizer to show what each font setting relates to on the site?
Before we go into what does what, can you disable the Ezoic optimizations on the site, and let me know.
Anonymous
Hi David,
Disable optimizations or diable ezoic whole? Ezoic has LEAP and I think there may be some flexibility but may just need to find out from Ezoic to be sure.
Stay tuned.
Anonymous
David,
Ezoic bypassed their setup to see what happened and the issue persisted. We’re no renaming the plugin folder to see if the issue persists. Or pinpoint if a plugin but if nothing comes up there, might be theme but we don’t know yet.
Anonymous
David,
In private section, some feedback from BigScoots.
Is Ezoic fully disabled , as i can still see a lot of its code being loaded on the site ? including the CSS optimizations it performs
Anonymous
David,
BigScoots (with alignment from Ezoic) says they think it is theme-related.
I don’t think it’s an issue with any plugins or cache. I have already tried disabling all plugins and it didn’t make any difference. You can check this with the theme support team.
Regards,
Gibu
http://www.BigScoots.com -
Can you make sure Ezoic is fully disabled.
And can you provide a temporary admin login to the site ? -
Anonymous
OK David,
I will setup the disable portion with Ezoic.
I will also setup temporary admin in private area and follow-up when done. Thank you so much for your help.
Anonymous
David,
We can’t completely remove Ezoic but there’s a setting to view old site with Ezoic. This is now enabled so no ads should appear.
Access details in private area.
Theres a login required before i can reach the admin screen ?
Anonymous
Sorry David. Too many things to remember. That’s a big scoots security feature.
I will ask them to either disable for your account or fully so you can go in. Will reply as soon as it’s confirmed.
Anonymous
The prompt has been disabled temporary to access admin page. Thank you.
OK, starting with the archive / home page – see here:
REMOVED
I adjusted the Archive Content Title ( H2 ) element as you can see it updates. I also saved it at 24px ( it was 20px ) and i can see the site is now using the 24px font size.
The Single Post:
REMOVED
I adjusted the Single Content Title ( H1 ) element and it too updates.
I did save a change, to see if it stuck on the front end and it worked too. I reverted that change.Som what am i missing ?
Anonymous
Hi David,
I will take a look but didn’t want my site exposed publicly. Is that something we can post in private please and delete public version?
Anonymous
Is there a setting for mobile pages and headlines to prevent truncating too lines?
