BigHef
Thanks. I’ve set all of the buttons to Block but still aren’t seeing any change.
Hmmm… the CSS on the buttons ( in sidebar ) all of them except the very last one is showing inline-flex.
And they all have the same CSS Class which means they are duplicates.
Can you:1. select the top button.
2. duplicate that button, and make sure its Layout is Display Block.
3. delete its original.Repeat this for the 2nd button.
Do those now fill the width ?
If so repeat those steps for the other buttons
BigHef
Thanks. I tried that for the first 3 buttons but again, haven’t seen any change 🙁
Hmmm… i am not seeing those changes on the front end. Is there a cache or CDN being used on the site ?
BigHef
I’ve disabled the Cache plugin the site was using (WP Fastest Cache) so I don’t believe so, no. The hosting is with WPX if that helps at all.
BigHef
So I don’t really know how or why, but I noticed one of the buttons was displaying correctly. So I’ve duplicated and renamed to create all the other buttons in that menu and it seems to be working.
I’ll try and replicate for all my sidebars now but even though there’s no obvious answer, I may be sorted. Will report back.
It sounds like some page caching is taking a while to clear. But let us know how you get on.
BigHef
So my fix ended up working – don’t know why or how, but it’s happy days in the end. Thanks everyone for all the help, very much appreciated.
Glad to hear that!
