Thank you David – I downloaded WPCode (Code snippets) plugin, created new, type=PHP. Cleared cache on browser and server. Issue corrected and did not have to re-type/edit pages. It also addressed header elements. Now, I just need to test on page SEO checker to see if it fixed errors.
You and your team are really incredible. You set the bar for support organizations.
David – back to the other issue discovered in this thread. Do you why incognito formatting is different from my normal browser mode?
Normal browsing mode uses caches, whereas Incognito does not.
So if you’re seeing a difference between the two then its generally related to caching.First try clearing ALL caches on the site, and in the normal browser.
Following up on this…
I had to turn off guest mode and guest optimization to get change to show on any browser other than the one I used to make changes to website. Unfortunatly these things have caused poor performance. I will crank up new post.
