aleksanderk
How can I set my blog page to be 3×3 grid (3 rows 3 columns) with “1…2…3 Next” activated? Exact layout like category pages have right now, I’ll link everything in private
so your site is using GP Block Element Content Templates.
Are you using different templates for your Blog and other templates for your Archives ?
aleksanderk
Hi David,
Yes, full context here: https://generate.support/topic/inserting-archive-card-element-to-a-page-homepage/
Since Archive Cards does not work on pages, I had to rebuild it using a query loop on a homepage separately.
You just need to add
blog
to the archive card element’s location. -
aleksanderk
It’s already there, I just need 3×3 layout with next activated somehow
Theres something not right with that blog page, can you share a temporary admin login to the site, so we can see whats going on.
aleksanderk
Added to private
I the Snippets plugin you have a snippet one titled:
ArchiveCardsHome
Can you disable that, as its altering the main query for the blog page.
aleksanderk
Ah right, forgot about that one, brilliant thanks. Can you check if the “Next” button is working for you? On my end when I hover it nothing happens when I click it and I am not seeing any URL come up
Its to do with the Footer, that Icon Headline block is overlapping the container.
1. Edit the Element titled Site Footer
2. select the Icon Headline – see here:https://app.screencast.com/LK5OludqblkMW
3. in Advanced > Additional CSS Classes add:
no-pointers
4. save that
5. add this CSS to your site:
.no-pointers { pointer-events: none; }
no-pointers
4. save that
aleksanderk
Excellent thank you very much. My final issue seems to be that it’s not pulling the most latest article right now but 2nd latest, how can I find what’s causing that?
Your latest post isn’t published yet, it’s still a draft. Query loop only show posts that are published.
aleksanderk
If you check /blog page specifically then it’s not showing latest post (PacketShare), it’s not using query loop but archive card element
1. The Blog heading element (previous was the content template for the 1st post) is nested in the Archive cards element, remove that:
https://app.screencast.com/Ebd1Y1IWl4huZ2. Go to customizer > layout >blog, uncheck the
Make first post featured
box. -
aleksanderk
I would ideally like to have that heading, when I tried to put the heading into archive card element itself last time it would give the heading to each individual card, so my solution was to just have it as a separate element to be injected.
Here’s blog heading drafted, how can this be fixed? https://imgur.com/a/HjfzEEK
Edit: Ah ok, I was writing this before your edit, okay layout is fixed, but how can I have the blog heading then?
