datatv
So here we go again! The problem is back! I already did a bunch of things suggested in the past. Cleared and Flushed cache. Deleted and re-installed GenerateBlocks. Regenerated CSS and changed the print method. Nothing works. Why is this so wonky?!
Sorry – Fernando is no longer working with us so we might need to refresh the issue a bit.
This is what I’m seeing currently:
https://www.screencast.com/t/nAYGYFbjFIs that not the correct layout?
If so can you clear and disable your caching plugin for us to take a closer look?
datatv
No. Definitely not. What you should be seeing is two columns of posts. Not one. And the hero on top should be much larger. Here’s a template that does still work and should show you whqt the homepage should look like.
I’m using LiteSpeed Cache and just disabled the plugin.
No change.
The previous replies have shown that this is not a GP/GB issue – it’s likely a caching or optimization issue still.
Are you able to restore a backup version?
datatv
Found the problem and it’s not caching. One of our editors created a post and somewhere in that post, no idea yet, has something that is causing to screw things up. Perhaps it’s because we’re using the Classic Editor and someone pasted Gutenberg code in?
I’m not sure but maybe.
If it happens again then you would just need to go through the debugging steps again – I think we can confirm that it’s not a GP/GB related issue.
datatv
I’m not so sure it’s not a GP/GB related issue. After all, it’s the code in the post that is screwing up the query builders where the post might reside in that feed. If it’s not in the feed everything is fine, and that’s likely why it was always displaying fine on those post types.
I think it’s fair to rule out GP and GB based on the previous replies and debugging steps.
We’ve not had other reports from other users either.
But we can cross that bridge if/when it happens again – a staging site would be a good idea for odd issue like this.
datatv
We don’t have enough room for a staging site based on our plan. So if it’s going to happen, it’s going to happen here.
