Thank you – that works! I am trying it on my other sites now
ETA: it doesn’t work on my two other sites ๐ I have put the admin login in the private information for them
You’re welcome, Tawna!
The code would work for all WordPress Excerpt Blocks so if you have other WordPress Excerpt Blocks that don’t have that issue, we’ll need to tweak the code.
If you have such a Block, let me know and share the link to it.
It doesnโt work on my two other sites ๐ I have put the admin login in the private information for them – they are set up exactly like mydogguide.com I’m fairly certain
In Appearance > Customize > Layout > Blog, can you update
Read more
toRead More
to test for these two sites? -
Yes – that worked! Thank you
I still haven’t updated my biggest site to WP 6.3 because of this conflict but I feel like I have to update at some point.
You’re welcome!
I see. If you do update, the same set of codes should work ideally.
Hi Fernando,
I finally decided to update my last site that wasn’t updated with wordpress – it is my largest site and I am needing other things in the wordpress updates so I had to update. However, this code does NOT work on this site. See the ‘read more’ not working on this page:
https://smartmomhq.com/family-time/please help
Thank you
ETA: I changed the CSS plugin and that worked perfectly — all is good for now – thank you
Hi Tawna,
How did you add the PHP snippet I provided on this site?
Hi Fernando and team – I have a site the read more is not working – please look back in this topic to see this was a GP problem and please help me get it fixed. I have applied the same thing to this site that I did with the other sites (as was recommended.) The site it is not working on is itstartedwithablog.com
Thank you
Hi Tawna,
So we can investigate, could you share admin login credentials to that website through the Private Information field?
Of course – shared – please let me know if you did not receive them – thank you
Could you turn the user provided into an Administrator?
Oops – sorry I missed that! done ๐
I replace
Read More
withRead more
in the code. It’s case sensitive which is why it didn’t work at first. -
Thank you! I do remember that being sensitive and I checked the Read More in the GP customize before posting but I didn’t check to make sure it matched in the code ๐
Thank you, Fernando -
You’re welcome! ๐
